Toyota yaris no power in fuel pump
Eiganram
Hi fellow , i have a toyota yaris 2010 and i am having problem with the fuel system.. i got no power in the fuel pump when i turn the key to ii position, no priming , no sound from the pump but when i jumper the pump it was ok . I was checking all the fuses and relay which turn out good except for the integrated relay which i dont know how to test . Is there any body can help me on this.
You should get a wire diagram from Toyota-tech.eu
It's payable access, cheapest one is 3 euros for 1 hour, but should be enough to get what you need. You can also print, or save the files.
When the key is on, did you check if there is power to the wires on the pump? Maybe contacts are just bad, and need a bit cleaning?
Moved to the Yaris club.
  • 4 years later...
I have the same problem used a power probe pump working fine plenty of fuel being pumped.....did you find what the problem was
