Help needed
Ritch92
Hi,  I have a 2007 2.0 td and all light except the engine management light has come on. I replaced the  Battery yestarday with a Toyota Battery
But the lights have returned and the car. Then will not start and struggles after 3 thousand rpm, I am thinking possible yaw rate sensor as this was another code but checked old Battery cleared codes and rescanned and it did not reappear?
Following the thread as my 2008 d4d is acting up, draining new Battery after 10 days but not flashing any lights in the dashboard.
Only tip is a fault code showing up when reading with diagnostics indicating yaw rate sensor...
