Multiple dash lights on (brake, abs, and traction)
suplene
The brake light, traction light and ABS light are randomly coming on all at the same time in my 2010 Toyota Yaris. This has happened several times and resulted in 4 wheel bearing replacements. I took it to the mechanic, but this time it does not appear to be a wheel bearing. Also, this time it occasionally has a very weird brake noise when the lights are on. Can anyone tell me what's going on?
Is the Battery original?
Low Battery voltage can cause all sorts of weird issues..
Check the votage first.
If it is original replace it.
