Hello
i have corolla 1.4 vvti e12 2003
i have problem with charging system on my corolla.  lcon of Battery on dasboard not turn on in second key positon and if i start with charged Battery after couple minutes car stop runing. I changed regulator on aternator and nothing happend
i want ask if anybody know what can be wrong and what i should try
thank you so much for answer and sorry for my bad english 🙂
A weak Battery is the likely cause or loose or corroded terminals
Have you checked the voltage from the alternator ? Did you also change the brushes ?
37 minutes ago, flash22 said:
A weak battery is the likely cause or loose or corroded terminals
Brushes are half ... so they need to change ?
and Battery is new .. so i can try tomorow clean or change terminals
thank you for answer
and battery is new .. so i can try tomorow clean or change terminals
Brushes are new they are in one set with regulator 😕
i forgot about that
