Locate Firewall Grommet
warmy
Hi everyone,
I drive a 2012 Toyota Yaris , and driver side is on the left side.
I am trying to install a new stereo unit and this unit required extra power to the Battery using a 12 GA power cable and ground cable grounded to a metal bolt.
I am not sure where the firewall grommet is to run the cable through. Is it on the driver side behind the Battery?
Thanks!
12 ga on a stereo ? it shouldn't need that sort of power, is it a cheap unit from China ? What value is the fuse on the stereo 5A, 7.5A, etc
Yes, 12 ga. It's a Sony DSX-GS900 with a built-in amplifier. It's a 15A fuse.
UPDATE: The power cable has a built-in inline fuse connector.
5 minutes ago, flash22 said:
is yours a mk2 or mk3 yaris ?
I think mine is mk2? Mine is a Yaris LE, 5-door
7 minutes ago, flash22 said:
USA xp130.
And thanks for the pdf! I will read through it. xD
EDIT: I looked everywhere for that PDF
