Fog lights
Lee_johnson1975
Hi folks hope everyone is well?
Further to my topic few days ago and thanks for the responses, just managed get my car through mot Monday, but this morning noticed both my front fog light bulbs are out, they were working other day...know on a 2008 they are a h11 fitment but how do you get in to swop them? Through the wheel arch?
Could be an electrical issue, not just a dead bulb. Checked the fuses ?
Do they have their own fuse? If so is it in engine bay or cabin? I had brief look earlier that fuse was also for rear number plate lights and fogs
I believe the cabin fuse box is under steering wheel kinda where your knees are?
Inside the car fuse box, fuse number 25 is for the front fog lights.
13 minutes ago, Lee_johnson1975 said:
Not the fuse checked
Hi, have you checked the connections at the lights , to access them you need to remove black plastic trays at both corners under wheel arcs. If you have a voltage meter you can check if anything coming to them., take the bulbs out and look at the wire inside. It’s strange that both lights suddenly goes.
I thought it was strange as well I'll check and change them anyway thought Id have go in through the arch
Switch? Multimeter would confirm.
I'll have a look when I can get out
