2014 replacement battery advice
My 2014 Verso Battery has died twice in the last three days.
I've managed to restart it using jump leads and taken it for a drive to charge the Battery. It seemed to run OK after that.
Today, it wouldn't turn on at all.
I'm going to put the jump leads on it again shortly but I just wanted to ask advice on the proper replacement Battery I should be looking for.
Are there any particular specs I must consider?
I was looking at Euro Car Parts and found a newer Exide battery which is 95Ah whereas my current battery is 80Ah. Does that difference matter?
Just the wrong time to have car trouble with CV and the virtual lockdown and unsurprisingly my local independent garage is now shut indefinitely.
Any advice would be appreciated. Thank you.
