Wiper blade replacement
Nannoo1969
Hi. I have ordered two different 28" Wiper Blades from eBay from 2 different sellers who say the blade fits my 2016 Yaris but the adapter doesn't fit so looking for advice on what wiper will actually fit? Any help on which blade has the correct adaptor would be appreciated. Thanks.
I bought this one for my wife's 2013 Yaris last year (now sold and we have a new Y20)
It fitted fine...I assume it should fit yours too.
https://www.ebay.co.uk/itm/TOYOTA-YARIS-2011-ON-quality-German-windscreen-WIPER-BLADE-28-replacement-kit/1225
ps...not sure if this link works...but if you look for a Heyner Yaris 28" blade..2011 on ...with the typical J hook fitting you should be fine.
No need to waste good blades if the adapter does not fit.
You can take the bought blade apart, pull the rubber out, and reinstall it on the one you have on the car now.
I did it few times already.
Yes I had to do that, the  hook end on the drivers wiper arm is wider than the passenger arm.
Hi, many thanks for the response but it's not a typical J hook arm which is why the wipers I ordered don't fit it. Sit sure where to look to be honest?
Hi, Thanks for the response but my 2016 Yaris has one single wiper in the centre?
Yes but the Same principle applies just change the rubber blade. Look it up on u tube it will show you how.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
