passenger window making crunching sound
okeydoke99
hi there passenger electric window wont go up or down al of a sudden
it makes a crunching sound
motor seems to be working i think but it makes this moise
driver window fine
this window started to have problems a while back it would go down ok
but on the way up it would stop halfway
and then go down again on its own accord
ne ideas
many thanks
neil
Sounds like the regulator and/or motor has gone bad, If it has been used much the rubbers around the glass go sticky and grab hold of the glass, but from what you are saying it gone beyond that point now
it may be worth cleaning the rubbers inside and out (hot soapy water) and try to get some lube in the tracks
What type of lube would you recommend in the track's Bob. Having same trouble with the Rav.
Something with Teflon or PTFE - GT-85
i have used a silicone spray in the past but it can smear up the glass
thanks guys
window wont go up or down just makes an rattling noise
when button is pressed as if something is turning round and round inside
motor seems ok
is it a big job?
how difficult to fit ?
any guides around on how to do it
many thanks for input
neil
Sound's like the window regulator to me, which would have little teeth on it and they would get worn off. this being the problem removal of the door car also the plastic behind the door card, and from what I remember when doing it on an old avensis or carina I owned removal of the motor and regulator and separating the two and replacing the regulator. Long time since I did it so just not 100%. But not to hard to do. if u can get the door card and plastic off and try and look at the regulator to see if the teeth are stripped on it. I imagine that is ur problem, the motor turning but the teeth on the regulator not able to grip. YOUTUBE IT MAYBE.
many thanks guys for all your help
i have ordered one off eurocarparts £53.00
i will probably get someone to do it for me
neil
well i purchased the regulator from europarts
and took it to my local mechanic to fit
the one that came off the car is nothing remotely like the one from europarts
there was only a choice of 2 on there website
looking on other sites they all seem to be like the one from europarts
so im stuck really
here is a pic
one that came off the car (top)
and one from europarts. (bottom)
