Engine block coolant drain plug
Mattch5150
Hi,all could anyone please just confirm to me where the engine block coolant drain plug on the 2008 2.2 d4d 140bhp model is. I think it's near the side of the oil sump but not 100 percent. Any pointers would be a great help,thanks again
Does anyone have any info re this,I've drained the radiator but cannot  find the block drain and can find nothing internet wide. Would be a great help
Well any  coolant left in block is staying there. I cannot find the port,and if it's manifold side then no chance getting to it with no ramp!
Usually you can loosen the hose clamps, remove the hose, and empty out the radiator.
Hi I've done that and got over 5 litres out, so happy enough, plus liquid looked good,no rust etc. The engine block drain usually doesn't yield much , I cant lie under that car any more so it will have to do. !!!
