2000 LE V6 O2 sensor locations/part numbers?
Hey y'all,
My car recently developed an error code P0136, indicating that the bank 1, sensor 2 (downstream) o2 sensor is out. Do any of y'all have a diagram or picture showing where this is? I'm pretty sure bank 1 is the rear bank of cylinders, so I could probably trace it out, but I'm not sure on that either.
Also, do any of y'all have a part number you'd recommend for a replacement sensor? I don't want to order one and then have the wires turn out to be too short.
I really appreciate any help or advice y'all have.
What model as heading says 2000 but profile says 2014? Can you post the chassis number?
You could use toyodiy or megazip sites...just pop in your Frame Number and you'll get a lot of info.
