Engine doesn't worked
szajba95
Hello,
I've a problem with my celica because two weeks stay at home and i can't drove it . Last saturday I wanted drive my celica but Battery didn't work then I charging the Battery and engine started fine but and drove somewhere. The problem appended when i stop the engine and next would't start again. I tried several time to not avail. I didnt hear pump work. When I checked fuel pump connected for a "short" with Battery and pump worked. The security immobiliser light doesn't worked how i would check the immobiliser?
Sorry for my bad english 😄
After you drove to where you were going, was there life in the Battery when you tried to re-start the engine?
Hi Karol,  Does the car start or try to start if you use another Battery.
