Headlight leveling motor Toyota Avensis T25 problem
Victor0019
I'm having a problem with my headlight leveling motor on a 2006 Toyota Avensis T25.
Unable to navigate the left headlight which remain fixed at a particular position. No motor movement.
The right headlight works perfect. You can hear it when it activates.
Anyone knows how to replace the leveling motor? Is there a need to remove the whole headlight?
Hello. This is code for leveling motor - 8566122020. But I think you need to verify sensors from below the car. They are positioned in front and back on the arms.
  • 6 months later...
hi there
i am having the same issue. headlamps not doing their little test movement anymore when starting the engine.
i was reading for the last couple of days a few diagrams but can't pinpoint the location of the sensors (t25 2.2 d4d 2005 european)
anyone knows how to: find them, test them and also if i could somehow test the headlamp motors by any chance to see if those are bad too?
i have the xenon automatic levelling headlights
thanks for your time
thanks but there is where i was looking for the last 2 days and can't find it anywhere
also on 7zap
14 minutes ago, furtula said:
If you have the part number, you can go to https://www.japan-parts.eu/ and check it out there.
It should show you the location on the car and surrounding parts.
10 minutes later i found the parts needed
now, before i go ahead and buy them, is there a way for me to check if those are bad or either the headlamp motor?
thanks a lot
If both headlamps stopped moving at the same time then it is likely to be the sensor.
