Language change
Eric mbaabu
Hi members, I have a Toyota prius v 2012,how can i change the language on the screen from Japanese into English? Thanks
Use your phone, start the google translate app, enable camera, it translates real time, select japanese, and into english, then let it translate.
Slow, but easy method.
Hi furtula,  have you actually done the translation? If the car in question is from the JDM the consensus is the language can't be changed as it is solely for the the JDM. An interesting topic if you have managed this. Edit  I may have misunderstood the question, yes you can read the translation but I don't think you can change the language settings. Doh.😀
