Which 12V Battery? Auris Hybrid
Filip D
Hi All,
My car needs new Battery but everytime i put my REG at Halfords it says no product/item matches it. Even when i put my model manually it doesnt come up with the product. Anyone knows which battery12V is a decent choice for Auris Hybrid (2013) - from Halfords or Eurocarparts?
Not everywhere stocks them as its an AGM type Battery, Toyota did do a flat rate on these batteries but there closed
iirc Yuasa are the oem - 2013 is one of them crossover years
2010 - 2013 HJ-S46B24R
2012 - 2019 HJ-S34B20L-A
Read the part number off the Battery
It is important you get an AGM Battery. Should cost around the £120-£130 mark, more then a standard Battery. Your Auris Battery is in the boot area. Therefore any rear end shunt could split open the battery and fly it’s contents, acid, over the people sat in the vehicle - not recommended. AGM are manufactured differently, therefore safer. Important to get right physical size, that the terminals are same as existing, that the polarity is same as existing, and that there is a vent pipe.
I understood that some Toyota service centres  remain open to service cars of key workers, if this is correct all op needs is to find one around him and someone with NHS card, so they can purchase a new Battery. Only suggestion, may work or may not.
Good luck
