Antifreeze for engine and invertor on a 2013 TS hybrid
Inf
Hello, I want to replace my antifreeze in both engine and invertor because am already at 250.000km and have a question on what kind of antifreeze shall i use and how much of it in both engine and invertor, if possible show me OEM numbers so i could search for it more easily
the antifreeze you need is an O.A.T. antifreeze
Featured snippet from the web
OAT is an acronym for Organic Acid (Additive) Technology which describes the type of materials responsible for the corrosion protection offered by a coolant of this type. ... A Coolant Extender can be used with an OAT coolant to top-up certain additives at the products half life which is typically around 480,000 kms.
Hi, engine coolant first change is at 100k miles 160k km, or 10 years, whichever comes first then after every 50k miles 80k km or 5 years. For the inverter first change is at 150k miles 240km or 10 years . Then is same intervals as engine coolant at 50k miles or 5 years. Coolant to use is this: https://www.ebay.co.uk/itm/223063212077 , if you can’t buy genuine Toyota ready mix coolant you can look for pink organic acid but nothing else. Electric pumps nd other components in hybrids are expensive to replace, don’t just fill any pink coolant in.
Regards
have Minerva Pink available near me, so was wondering if its any good
it needs to be O.A.T. antifreeze
i cannot see any references to O.A.T. on the bottle
