2001 front wheel bearing
Stuartyaris
struggling to do front wheel bearing on 2001 yaris,what is the hub nut size and what's it called please,clean answers only!cheers stu
A Hubnut or front axle nut
size 30mm if it's not a standard hex it will be a 12 point, but feel free to double check it
30mm is 1-1/4" and you will need a breaker bar or an impact
Look at my post from last year -
I have different sockets to cover most sizes. Toyota use 30 mm though some kits supply 32 mm nut in the kit! I have done a few wheel bearings and have my own 10 ton press. Now some of the cars like my current Avensis, have the bolt on hub bearing. Done them too, especially on a Prius. Your car would be easy.
