Avensis t27 alternator
310cjc
Hi Just wondered if replacing the alternator on my  2014 Avensis 2.0 d4d T27 requires the RH drive shaft to be removed as it did on the T25 models
I would say yes. You will need to check the gaps and remove the under tray to see how much space.
