Rear Door external moulding/fairing
ICF
Can the rear door external door moulding / fairing be bought pre-sprayed for Yaris Design 2017
I doubt it Ian, but I suspect you need to be a little clearer as to what you mean.
I have genuine door moulding strips on my Yaris. Purchased and fitted myself. They came unpainted. In the Toyota fitting instructions there was also the painting procedure. I left them black, as supplied.
The purpose of the side mouldings is to protect the doors from others opening their doors against yours, etc. Although colour coding them to match the body colour may be preferable to some, if the subsequent painted moulding gets chipped it can look more unsightly.
          Yes they do a good job of protecting the door as we found out that's why I need a replacement.☹️.
I just thought they might come pre-sprayed like the wink mirror covers do.
it comes in 2 parts in your picture the piano black part and the body colour part
you dont say what side
eg.
75741-0D200 and 75797-0D050 (not these may not be right for your car and are just an example)
4 hours ago, ICF said:
This is the part I'm enquiring about.
LHR fairing 75742-0D210 £53.72 + VAT part is primered and requires painting
LHR Fairing insert ( piano black ) 75744-0D021 £49.47 + VAT
there are also rubber finishers & retainers required as per the pic
Yes sorry it's the left had side as per the picture.
How easy is it to fit?
Do you need to remove the inside door panel to fit it?
