Aygo 2007 rear windscreen washer not working
Tom Bright
Not sure if this has been bought up before (I can't find a thread) but my 2007 aygo rear windscreen washer is not working, can hear the motor and the front washer is working fine... does anyone have a tutorial or links on how to replace the pipe or pump or any suggestions would be great?
Get a long pin poke into the nozzle try to clear it if nothing could be broken pipe somewhere
Sent from my G8341 using Tapatalk
Will try that, hard to locate which pipe it is as the tank is tucked right away under the right headlight😅
