Lose oil
ZNiko
Hello my Toyota Yaris 2008 loose oil In between oil changes. Anyone can help?
Sent from my SM-G955W using Tapatalk
How much oil over how many miles/km? Which engine do you have - 1.0, 1.3, 1.8 petrol or 1.4 diesel?
Yaris Hatchback 1.5 Le ,i change the oil every 8.000km at the Toyota Dealership Not Synthetic the km on the yaris is 218.000
I check the oil stick and the oil is less than half close to minimum
The only thing i notice is when i turn on the heater sometimes i can smell burning oil and i show oil behind the engine f1dd13c960a70d1a49e3fe9ea7707680.jpg
Hi, have you checked for oil leaks? It sounds like you may have a bad oil leak from somewhere, if you haven’t checked yet it is a good idea to do so.
Regards
At 218000 km, it  does not surprise much that it's consuming oil.
If it uses up around 1L per 10k km, i would consider it normal. That's my case now, and was with my previous 1.6 petrol non Toyota car.
Given the mileage and you can smell burning oil, the cam cover gasket needs replacing you  may also find the spark plug holes have oil in them too
I order from Toyota dealership the valve cover gasket, but the don't sale rtv sealant, any Suggestion what rtv Sealant can i use they have so many different types?
You shouldn't need RTV other than to hold the gasket while installing it, not sure what country you are in if its in the states - Permatex ultra black is the go to
