Avensis T27 roof bar parts info required please
SAM LOVERS HER TOYOTAS
Hi Guys,
I purchased a beautiful set of genuine Toyota roof bars as a gift for my hubby on eBay, he's always wanted some to use as a bike carrier at some point, anyway, my issue is as they have been used! We didnt get the 4 sticky pads (see item G in pic below) that go inside each door well.
Does anybody know what size they are AND if I could maybe make some but using what though???
Look forward to some responses guys, Cheers.
Sammy
P.S...re item "D"...does anybody know what these do exactly...so strange !!! Something to do with aerodynamics maybe?? But why on the one bar though?
Hi on the roof bars for my Prius I used them to protect the paintwork where the clamp goes under the gutter
D. Your correct they are for high speed noise, and they go on the under side of the front bar (page 6)
G. Single sided foam tape that goes on the inside the door jam to protect the paint where the clamp sits as per the instructions (page 5)
eg. https://www.ebay.co.uk/itm/Scapa-Black-Single-Sided-Foam-Tape-3mm-Thick-Available-in-12mm-25mm-50mm-Width/121812697370?hash=item1c5c9a411a:m:mBcIKCN3wLzLrbIkFsvHqfA
25mm wide should do the job
Hi there is a video which shows you how to fit roof bars for a Toyota
Cheers guys for all the above,
Cant wait to source the single sided foam tape and get them fitted
