I have a 2002 corolla I really want to.be have folding mirrors for it any way of possibly doing this
Is there a model that has power folding mirrors in the UK?
Naomi Campbell?
  • Haha 1
You can adapt the mirrors of the avensis t25, from 2006 they have integrated turn signal lights
https://www.clubtoyota.es/viewtopic.php?f=3&t=8046
https://www.clubtoyota.es/viewtopic.php?f=3&t=12657
You can also buy the ones from the US altis, they fit perfectly
https://www.ebay.com/itm/190681775736?_trksid=p3984.m1497.l2649&item=190681775736&cmd=ViewItem&sspagename=STRK:MEWNX:IT&vxp=mtr
or you can opt for corolla e12 runx altis wagon (japan) with or without turn ligth signal, for example
https://www.ebay.es/itm/Wing-Side-Mirror-Folding-RIGHT-Fits-TOYOTA-Altis-Corolla-Runx-Wagon-2001-2006/192014792866
or finally you can choose
https://www.recambioscoche.es/recambios-buscar.html?keyword=adp636
for any of them, you must put a folding controller and the avensis controller fits perfectly, and you must pass wiring too, for example
https://www.ebay.es/itm/2007-TOYOTA-AVENSIS-2-0-D-4D-T3-X-5DR-ESTATE-POWER-FOLDING-WING-MIRROR-SWITCH/193096601746?fits=Model%3AAvensis|Plat_Gen%3AT25&hash=item2cf5745092:g:b9YAAOSwzthdeQlf
From China you can also find different compatible pieces for interiors cheaper than the original ones. for example BYD F3
https://es.aliexpress.com/item/32884728654.html?spm=a219c.12010615.8148356.33.588e2115QyIhut
https://es.aliexpress.com/item/32883253302.html?gps-id=pcStoreJustForYou&scm=1007.23125.137358.0&scm_id=1007.23125.137358.0&scm-url=1007.23125.137358.0&pvid=179ca2ff-77c7-49ed-a539-6f2e683026ae&spm=a2g0o.store_home.smartJustForYou_816184116.2
https://es.aliexpress.com/item/4000682793489.html?spm=a2g0o.detail.1000014.5.759c84594rm0pF&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.14976.158757.0&scm_id=1007.14976.158757.0&scm-url=1007.14976.158757.0&pvid=7afa431d-acc6-4f14-98f4-a039c261f08b&_t=gps-id:pcDetailBottomMoreOtherSeller,scm-url:1007.14976.158757.0,pvid:7afa431d-acc6-4f14-98f4-a039c261f08b,tpp_buckets:668%230%23170728%234_668%23808%233772%23979_668%23888%233325%2319_4976%230%23158757%230_4976%232711%237538%23349_668%232846%238116%23987_668%232717%237558%23180
https://es.aliexpress.com/item/4000225679825.html?spm=a2g0o.detail.1000014.7.32dd5149fOmqQE&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.14976.158757.0&scm_id=1007.14976.158757.0&scm-url=1007.14976.158757.0&pvid=5ff43958-d370-42d0-949a-ad4105eda33f&_t=gps-id:pcDetailBottomMoreOtherSeller,scm-url:1007.14976.158757.0,pvid:5ff43958-d370-42d0-949a-ad4105eda33f,tpp_buckets:668%230%23170728%234_668%23808%233772%23979_668%23888%233325%2319_4976%230%23158757%230_4976%232711%237538%23349_668%232846%238116%23987_668%232717%237558%23180
https://es.aliexpress.com/item/4000667985104.html?spm=a2g0o.detail.1000015.1.32dd5149AYCjYY&scm=1007.14452.154761.0&scm_id=1007.14452.154761.0&scm-url=1007.14452.154761.0&pvid=f803421c-4bab-4fbc-b666-ac13b4461b70&ad_pvid=202005010311395014653874738401929469_2&fromDetail
Thanks plenty of information I had a feeling adaptions from the US models could be a possibility. Excellent.
You can put in avensis controller and wire, or you can pass it directly to the contact and so when you give the contact the esopejos will open and when you remove the key they will close
You can put in avensis controller and wire, or you can pass it directly to the contact and so when you give the contact the mirrors will open and when you remove the key they will close
