Avensis t 180 injector o rings
Roscoe1968
Hello everyone
I have a 2007  2.2 t 180 estate ,the enjector seal has gone ,removed the injector ,and the rubber o ring ,had gone hard and broken up.
I have tried eBay for new ones ,but can't find any for my car ,can someone point me in the right direction ,I need them asap ,many thanks in advance
In case you dont find it, maybe try one of the sets with different sizes, usually you can find one that fits in those.
Moved to the Avensis club.
The rubber "O" rings are just dust seals designed to stop water/dirt from entering from outside there are compressible washers that seal the injector to the head these contain the combustion within the bore not the "O" rings see pic attached, 11176 is the washer with the "O" ring above to refit the injectors you will need:
4x 96721-19017 "O" ring
4x 11176-26010 seal
make sure you remove all 4 washers as you cannot double them up.
Check your local Toyota dealer as we are slowly staring to open again or a local diesel injection specialist
Toyota Owners Club - Toyota Forum
Follow 0
Used Fuel Injectors D4D?
By mladenpet, August 17, 2012 in Avensis Club
mladenpet
  • New Member
  • Registered Member
  •  0
  • 2 posts
  • Toyota Model: avensis d4d
hello,
i have avensis d4d 2.0 with all 4 fuel injectors bad, whole body of injectors has gone bad. I have denso injectors not Bosch.
How and where do i get used fuel injectors? I don't need only part that can be changed but whole fuel injector that works, taken from car that was in a crash or something like that. Because 4 new injectors from toyota cost around 2.500e.
How can i find them and be sure that they are fully working? I saw few on eBay.co.uk but i am not completely sure if they work and i am not from UK.
Any info would be helpful, thank you.
Like
Jas16
  • Advanced Club Member
  • Jas16
  • Registered Member
  •  0
  • 129 posts
  • First Name:Jas
  • Toyota Model: Avensis 2.0 D4D T3-X
  • Toyota Year: 2006
Others can correct me if I'm wrong, but I believe that getting a set of injectors from a scrapyard etc would be possible, but they would have to be caliberated via software which can only happen at a good independent dealer or a main dealer only which will cost
unfortunately there isn't really a cheap fix as such
Like
t-spiritpete
  • Top Rank Poster!
  • Registered Member
  •  118
  • 1,779 posts
  • First Name:Pete
  • Toyota Model: Avensis 2.2 d4d t-spirit and Yaris 1.3SR Nav
  • Toyota Year: 2007
  On 8/17/2012 at 3:47 PM, mladenpet said:
hello,
i have avensis d4d 2.0 with all 4 fuel injectors bad, whole body of injectors has gone bad. I have denso injectors not bosch.
How can i find them and be sure that they are fully working? I saw few on ebay.co.uk but i am not completely sure if they work and i am not from UK.
Hello mate,
I am led to believe one of the best companies in the UK to deal with are Feather Diesels Halifax and comes well recommended, I have no connection with this company. Maybe an email or phone call to them may point you in the right direction but as jas16 says they can only be fitted by a Toyota dealer or someone like Feather Diesels who have the equipment on site.
http://www.feather-diesel.co.uk/
Regards Pete.
Like
Parts-King
  • AUTHORISED TOC TRADER
  • Parts-King
  • Authorised Trader
  •  650
  • 10,587 posts
  • First Name:Kingo
  • Toyota Model: Corolla 1.8 Icon Tech Hybrid
  • Toyota Year: 2019
Any of the Denso dealers will help, PF Jones in Manchester for instance. They have to be programmed to your car
Kingo :thumbsup:
Like
Lindop Brothers Toyota Genuine Toyota parts at DISCOUNTED prices.
Please don't make me guess what car you own ALWAYS quote your registration number when making parts enquiries. Thanks :thumbsup:
Powered by Pies
mladenpet
  • New Member
  • Registered Member
  •  0
  • 2 posts
Oh thanks for fast replays, this forum is really active :)
I sent emails to those companies.
feather-diesle says they are repairing broken injectors. My whole injector if flawed, not just the thing on the end, but the body and electronics of fuel injector.
My avensis works fine when started, but it won't start when its hot, i need to wait for 1h to cool down.
Did someone bought refurbished and used fuel injectors before?
Like
Grey v
  • New Member
  • Registered Member
  •  0
  • 8 posts
  • First Name:paul
  • Toyota Model: corolla verso 2.0d4d
  • Toyota Year: 2004
Hi I have a similar problem on a 04 verso 2.0 d4d does anyone know If secondhand injectors can be programmed into the ecu ?
Like
Devon Aygo
  • Staff Member
  • Devon Aygo
  • Super Moderator
  •  751
  • 3,335 posts
  • First Name:Lee
  • Toyota Model: 2019 Corolla 2.0 Excel HB , 2016 Yaris Excel Hybrid Premium (Parents)
  • Toyota Year: 2018
PM your chassis number, as Toyota have started to offer reconditioned injectors so there may be a factory approved reconditioned injector available for your car.
Like
Grey v
  • New Member
  • Registered Member
  •  0
  • 8 posts
  • First Name:paul
  • Toyota Year: 2004
Thanks Devon i have contacted feather and they only have a new injector listed for my registration model so I took it they didn't do a recon I will have to contact them and ask them wether secondhand can be programmed in I will ring round again in the morning cheers
Like
Grey v
  • New Member
  • Registered Member
  •  0
  • 8 posts
  • First Name:paul
  • Toyota Year: 2004
Like
Devon Aygo
  • Staff Member
  • Devon Aygo
  • Super Moderator
  •  751
  • 3,335 posts
  • First Name:Lee
  • Toyota Year: 2018
Not sure where feather source their injectors from, but Toyota have introduced reconditioned exchange injectors on some models but I would need a chassis number to confirm if they offer the option on your car
Like
Grey v
  • New Member
  • Registered Member
  •  0
  • 8 posts
  • First Name:paul
  • Toyota Year: 2004
Thanks mate I will pm you the chassis number in a bit 👍
Like
Peter ndovi
  • New Member
  • Registered Member
  •  0
  • 1 post
  • First Name:Peter ndovi
  • Toyota Model: Avensis d4d icon
  • Toyota Year: 2014
What's the estimated cost of replacing fuel injectors in an avensis d4d icon
Like
peter.ling24@gmail.com
  • Registered Member
  •  16
  • 159 posts
  • First Name:Peter
  • Toyota Model: Avensis t spirit
  • Toyota Year: 2005
Hi Steven,
It might be worth giving this fellow a call.
 Jon Pick, who is a Diesel fuel specialist. He helped me source 4 denso injectors and seals for my 2.2 D4D.
I have contacted him to ask his permission to pass on his contact details.
Mobile number 07974 681667.
I hope this helps if you haven't already fixed the problem.
Peter ling
home-icon.png Home     Latest Posts     News     Photos     Videos     Contact Us
Toyota Owners Club UK © 2020 | This Website has no association with Toyota (GB) or Toyota Motor Corporation. | Cookies | Privacy Policy | Terms & Conditions
Sorry,
I seems that I cut and pasted an entire reply to a previous enquiry.
Apologies.
Peter ling.
  • Haha 1
