I have a Toyota Corolla Verso 2007 Diesel. A couple of weeks ago it would not start and I tried to get it going myself, everything was working (radio, interior lights, central locking) just the car would not start. One of the things I tried was to disconnect the Battery for 30 minutes and then reconnect it. After I reconnected the Battery, central locking, radio and interior lights stopped working. I called out a mobile mechanic who managed to get the car started again, he said that it was a faulty fuse. He tried to get the radio, interior lights and central locking working again but said he had checked all the main fuses and they were fine and that I would need to go to an automotive electrician. I am worried that this will be expensive and was hoping somebody might have some suggestions of things I can try myself?
Check the Dome fuse under the bonnet
Thanks, I had a look under the bonnet and could not find the Dome fuse. Could it be anywhere else?
Found it, changed fuse and this solved the issue. Thank you so much for your help.
