Cruise control in a 04 Avensis D4D
Hello again
I've been studying the subject and as far as I know you can fit a cruise control if the throttle body is manual - it has to be electrical. My model is 2004 2.0 D4D manual transmission. I've checked my throttle body and it has got a cable on it. Is it still worth to check the pin in the ECU to see if the dash control lights up?
I've found a firm and they sell a full kit for 03 - 06 Avensis. It includes the ECO and other gear. Does it mean that even if you have a manual throttle body you can still fit a cruise control?
http://www.canm8.com/cruise-control-systems/toyota-cruise-control/precision-cruise-toyota-avensis.html
limiter_4_1_1_1_1_1_1_1_1_1_1_1_1_2_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1.png
new_cruise_2_4_1_1_1_1_1_1_1_1_1_1_1_1_1_2_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1_1.jpg
If it was me i'd be looking on eBay for a steering wheel with a cruise switch fitted.This is what i did and mine works a treat.Search for the Cruise thread on here .There's one here for 45 notes,just swap the air bag onto this and you're good to go.
https://www.ebay.co.uk/itm/TOYOTA-AVENSIS-MK2-T25-D-4D-STEERING-WHEEL-2008/202765395469?hash=item2f35c2660d:g:FhUAAOSwxMhdZNRm
3 hours ago, Exvec said:
If it was me i'd be looking on Ebay for a steering wheel with a cruise switch fitted.This is what i did and mine works a treat.Search for the Cruise thread on here .There's one here for 45 notes,just swap the air bag onto this and you're good to go.
I've been thinking about getting a steering wheel with the CC. Plug and play. The point is do I have the CC in my ECU? The throttle body has a cable, it's not electric.
 My car is a 2006   1CD FTV 2.0 d4d engine  and mine was just plug and play that's it,?which engine does yours have.
I've got a 1CDU FTV 2.0 D4D from 2004. I've found exactly the same car as mine is and it has got a cruise control.
https://www.autotrader.co.uk/classified/advert/202005139304399
