Pinout
3G - pin 4 (12v permanent live) Grey (dome fuse)
3G - Pin 1 (12v switch live) Red (Back up Fuse)
3C - Pin 6 illumination Green (tail fuse)
3K - Pin 1, DLC pin 4 or anywhere there is bare metal -  Ground
DLC - Pin 9 tach signal
2 hours ago, flash22 said:
Just collated some info
looks like it comes through 3 wiring combs, and they are a pig to work with (usually taped up in the main loom)
i will see if there is an easier place to get them from
What radio do you have ? Does it have Bluetooth and USB ? or just an AUX socket on the front ?
Mine is non bluetooth. Poverty spec so just the aux input.
ok see my last 3 posts and the attached pdf's
  • 1 year later...
Can anyone help me in locating where I can pickup the tacho signal from?
I do not have the plug in my 2013 wiring loom and have no idea what or where AC2 is or DLC - Pin 9 tach signal
Hoping some one can point it out to me a photo would be great
DLC (Data Link Connector) aka OBD2 port
Ac2 is on the drivers side up high, it's a dash out job to access
Please ignore the TS and CG labels
Hey many thanks for that I will have a look at the OBD2 port to see if the wire is there and piggy back onto it
