New Exhaust
vitzpower
Hi all,
I've just got my Blitz Nur Spec R muffler fitted to my T-Sport. Pricy bit of kit, but starting feel that it's worth it with the increased performance I'm getting in return.
One question, is there a cat back pipe available that is compatible with the Blitz? I tried Racelogic (where I got the piece from), but they said that they only supply the muffler. Any ideas/links?
Ur location bit isn't filled out on the left but if u are in the UK u could just go 2 a powerflow shop/centre and they would do u a SS cat back pipe if u wanted!
Cheers :thumbsup:
Ryan1985, yes I am located in the UK. Would there be a web link for Powerflow?
Would a cat-back pipe really make any difference? The pipe is pretty short and is the same width as the Blitz back end. Would you not be better off with removing the cat altogether?
True, but wouldn't that fail the MOT?
In that case, leave the cat on but replace the resonator thats inbetween it & the back box. Funnily enough, I'm thinking of getting powerflow to do that with my nur spec...
Probably not much bhp increase but it will last forever so who cares? It will save u money in the long run dependin on how long ur keeping the car 4!
And yes the car would fail an M.O.T without a Cat and it seems more hassle than its worth 2 keep takin it off and puttin it back on etc!
Cheers :thumbsup:
But would there be much performance increase with that though?
less back pressure = less bottom end torque, apparently <_< . Might scream along a bit better near the red line tho :D
