2020 Camry Software Update - Apple CarPlay in EU
your model is the same as mine
We seem to have everything else the same except for "Parts No. DCU" I have "86140-33D80" and you have "86140-33D81". Does your service menu have the same values for "FROM" and "FROM2"? FWIW, I have the JBL system.
If so, I'm assuming I can just replace "86140-33D81" in the guide with "86140-33D80" (folder name, VP_PANA_maker_ID) and it should just work™?
My model is 86140-33D81, but my friend has the model 86140-33D80. The process is the same for all.
Hi.
I was able to do the USB1 -> USB2 -> USB1 sequence. Success!
However, I can't figure out "Step 5":
Quote
From the root you delete the phaseup.dat file
There's no phaseup.dat in the provided "86140-33D81.zip".
Quote
and rename the next file with the version obtained by other colleagues.
What file? Where do I get this file?
Here's how my USB stick (this one is the USB3, right?) looks like:
I did try to use this USB exactly like this, and I also tried to modify the `86140-33D81` to `86140-33D80` (and change the other values as specified in the guide), but no luck.
My audio version after USB1->USB2->USB1 is 1011 and Navigation version is 1170.
Hello, Im trying to get it working on my car, but I dont understand where do I get all the files, even tried toyota official servers. If someone can help, please PM me.
Hi, you have three pen drives here: https://www.dropbox.com/sh/0voix1me6n5ad9o/AADyWxg7ugvhM2wNVEpKqga1a?dl=0&fbclid=IwAR3pzQiPipkqapqxVdv9VdkiKVQxJeFEVdZrUCyoywYAUzGx-rFqzOcQJzk
On 6/3/2023 at 11:46 AM, Alcar said:
This system is only for Panasonic.
In Fujitsu you need to write a internal memory, it's easy but it's not a pendrive USB
Hi in this case we will write internal memory with files available in USB? I have left a personal message your reply will be very helpful
Hi, if you are asking about Denso then you have to use programmer to flash the SPI_Flash direct on the board.
Yes i am talking about denso, i understand what you mean and i know how to do it.
but my main concern is that my file is 17TD1ME-CA01 so can i flash dump 17TD1EU-CA01
also any link to forum where people are doing this
Hello everyone,
I took upon updating the software as well, but not quite getting the desired results.
My starting numbers were the following:
DCU: 17TDT2EU-DA01 / 86140-33D81
MEU: 17TMT2EU-FA00 / 86840-06041
Audio: 1042
Navigation: 1540
I did the USB 1-2-1 thing (using the files linked in this thread previously), after that the updated values were:
MEU: 17TMT2EU-FA10 / 86840-K0010
Navigation: 1120
Now, since I have the same DCU number as Alcar, I just used the modified files that he uploaded for USB3 (again, using the previously linked USB files). I did delete phaseup.dat, but did not rename anything, since it already looked like what I'd expect the end result to be based on the guide:
PreInstall folder:
VehicleParameter/DCU folder only contains Alcar's upload:
Now there was only one value that got updated:
Audio: 1020
This, from what I understand means that I did something wrong.
I went ahead with the final MEU update hoping that it will fix things, but that again only changed one thing:
Navigation: 1170
I did the delete user data thing, but I still don't have carplay. Does anyone have an idea about what might have I done wrong?
Some notes, not sure if they are related:
- Navigation did break for me after the initial MEU upgrade this point (thought I was in Belgium for some reason), but the DCU update fixed it.
- Initially inserting USB 1 didn't do anything for me, but I could still install from USB 2. Still, I inserted USB 1 after that again, just to be safe. When I did the other MEU upgrade, I did get a loading screen with USB 1 though, installed USB 2, and then inserted USB 1 again, which again did not seem to do anything.
1 hour ago, ldani7492 said:
Hello everyone,
Audio: 1042
Navigation: 1540
Navigation: 1120
PreInstall folder:
Audio: 1020
Navigation: 1170
Maybe you didn't rename the kwi?
DA31 -> DA01
The version 1020 has no carplay.
The version 1023 has carplay.
Regards
DA31 -> DA01
Regards
Ah, you were right. It seems to be working now, thank you very much.
Hello!
I also have a 2019 Camry and I would like, if possible, to help me install AA.
My navigation model is:
DCU 17DT2EU-DA01; 86140-33D0
MY 17TMT2EU-FA00; 86840-06041
Audio 1011
Navigation 1520
Navbd_version 2022_v1
FROM CV-CS88E0AJ00
FROM2 CV-CS88E0AJ02
I have read the manual created by Alfonso, but I still have some questions:
1. Can I update this unit?
2. USB2 is copied into the FMU folder, only the kwi (17TMT2EU-FA10) or is it necessary to install 17TMT2EU-FA00 first?
3. USB3 I downloaded what Alfonso put, but I can't find a folder similar to what he has (86140-06500) and when I open SYS_SUM_EEPROM.bin I don't see the same version and I don't have that "1" either.
Can someone who has done this before help me? There are many similar questions on the thread that have not been answered.
Thank you very much! 😊
On 7/21/2023 at 8:22 AM, PanaAdrian said:
Hello!
Audio 1011
Navigation 1520
FROM CV-CS88E0AJ00
FROM2 CV-CS88E0AJ02
Pana write a private message 🤣
DA31 -> DA01
Regards
That's what bothered me the most!
You have to rename DA31 and REPLACE the existing DA01. It wasn't clearly stated enough in the Alcar manual (I do not unappreciated your work Alcar!), so it took some time for me to figure it out.
  • 4 weeks later...
Quote
This part is not clear for me as well....
What exact actions should I do with USB 2? Copy xxxx-fa10.kwi and place along others?
and rename it, remove fa00? any others? neither of them?
On 7/21/2023 at 9:22 AM, PanaAdrian said:
Hello!
Audio 1011
Navigation 1520
FROM CV-CS88E0AJ00
FROM2 CV-CS88E0AJ02
Did you manage to update this, seems like I have the same version what you
86149-33D00
and I updated only to version audio: 1020, navi: 1070 and navidb: 2018_v2, any hints?
greetings all. Issue is with a Rav4 but this is the closest match a search brought up...
I'm trying to do an MEU update on 17MT2EU-FA10 from 1120 to the current 1170 but get an error "insufficient memory, see you dealer"
has anyone seen this or have any clue how to clear the required space please?
thanks, David
@Devon Aygo seen anything like this before plz?
I just wanna say thanks to Alcar for a great post and a great manual to finally get Android Auto in my car.
Read Alcars post three times, then read the whole thread once and you will find the missing pieces.
  • Haha 1
Thanks to all ! carplay works. Only the standard navigation does not work at all, version of maps 2021v2... what could be the matter?
dcu 17TDT2EU-DA00 <-  DA30
mcu 17TMT2EU-FA10
Hello. Help please. There is a dcu 17tdt1eu-ca01 device. How do I install appleCar for it?
No, it's only for Panasonic
Hi there!
I was reading this topic about 5 times and still there is something that is weird about it. I did the update but in the way of USB3 - USB1 - USB2 - USB1 because USB1 did not start at first and I wanted to test other USB - will upgrade button light up. USB3 started... My hardware is just like alcar's. Now I have a working AA but I can't see it in Media section. Only way to get to AA is by audio source. That is awful because I can't run radio and google maps in the same time.  Now my versions are: Audio 1023, Navigation 1530, Navdb 20019v2 and I can't upgrade navigation - car does not see the upgrade file on USB. Please give me hint what can I do to make it work normal 🙂
27 minutes ago, yasiu87 said:
Hi there!
To change the radio input, use mode button in the steering wheel.
The Toyota system don't allow using both "channels"
