2020 Camry Software Update - Apple CarPlay in EU
On 6/9/2024 at 1:14 PM, Alcar said:
I sent a private message.
Hi WLF46 it's only a license problem but our car support Carplay and Android Auto.
My DCU is 17TDT2EU-DA00 too. I can`t find update USB3.
3 hours ago, Kirill_TSK said:
What's the problem?😅
On 6/17/2024 at 8:50 PM, Alcar said:
I think that it's impossible because the decision to install this software live out of Europe.
If you achieve that people can install Android Auto of official way it will be a big new 😊
Good luck 😊
But that's the idea - if we're able to group up and express our complaints as a consumer mass - like they do in the U.S. all the time, then Toyota might take action - which in this case will be to just allocate some resources to fix this. If it doesn't require any physical changes to the vehicles - only a software tweak, then it is ridiculous not to fix this. I know they did a similar thing to old Mazda CX-5s - they offered retrofit addition of AC and AA after 8 years - customers had to pay like 500 bucks for it, but still.
On 3/29/2023 at 8:20 PM, Alcar said:
I send you a private message
Hi, can you send me details on how to download USB1 USB2 Usb3 file as well? thanks
On 1/23/2024 at 11:51 AM, CrazyCatman said:
When you enter Setup and go to Software Update, can you then send me the following:
Model-id DCU (that should be 17TDT-something most likely ending on DA-someting)
Model-id MEU (that should be 17TMT-something most likely ending on FA-something)
Audio (four numbers)
Navigation (four numbers)
Then I can be sure to give you the correct files for the updates you need. I believe you will need all three sticks. With a 2020 model I believe the USB3 files provided from Alcar is the correct ones for you - then added USB1 (boot drive) and USB2 (MEU update)
Hi, I wonder if you can help me install and update my multimedia in my 2019 Rav4, do you know where I can download the USB1 USB2 and USB3?  I am a little too old now for editing the files.
here is my multimedia details:
Model ID DCU    17TDT2EU-DA01
Model ID MEU    17TMT2EU-FA00
Audio                  : 1020
Navigation          : 1512
navdo_version    : 943
DCU: 86140-42570
MEU : 86840-06041
thank you!
On 6/6/2023 at 10:25 PM, landjalan said:
I am still very confused by what I have to do and how.
I got this USB1 folder, inside the folder I change nothing. I guess I use the folder only to start the car software update (right?).
After USB1, when do I need to insert USB2 ?
For USB2 I have to download the file from the polish colleagues ? In my case I downloaded 17TMT2EU-FA10_1170.kwi. I guess again I add this file into the USB2 folder where are a lot of other KWI files. Do I have to rename something here ? My current version is 17TMT2EU-FA00. Will the software update know what to do, or do I have to rename the existing kwi file of USB2 17TMT2EU-FA00_1900.kwi to the newer downloaded file 17TMT2EU-FA10_1170.kwi ?
I guess I try first updating the MEU and then the DCU later if everthing with the MEU worked out fine.
Thanks a lot !!
May I know what solution had you made in here? Thanks
On 7/18/2023 at 10:08 PM, ldani7492 said:
Ah, you were right. It seems to be working now, thank you very much.
hi, from where did you rename this DA31 -> DA01 ?
On 4/24/2023 at 8:32 PM, Tibi said:
I have finally run it, but in the end there is no either android auto nor apple carplay. This is the final screen. I have done what it has required, deleted the personal datas, but still nothing. Any idea?
Hi, may I know how did you troubleshoot this afterwards?  I experienced this as well but nothing happens to my multimedia
On 7/18/2023 at 9:48 PM, ldani7492 said:
Hello everyone,
I took upon updating the software as well, but not quite getting the desired results.
My starting numbers were the following:
DCU: 17TDT2EU-DA01 / 86140-33D81
MEU: 17TMT2EU-FA00 / 86840-06041
Audio: 1042
Navigation: 1540
I did the USB 1-2-1 thing (using the files linked in this thread previously), after that the updated values were:
MEU: 17TMT2EU-FA10 / 86840-K0010
Navigation: 1120
Now, since I have the same DCU number as Alcar, I just used the modified files that he uploaded for USB3 (again, using the previously linked USB files). I did delete phaseup.dat, but did not rename anything, since it already looked like what I'd expect the end result to be based on the guide:
PreInstall folder:
VehicleParameter/DCU folder only contains Alcar's upload:
Now there was only one value that got updated:
Audio: 1020
This, from what I understand means that I did something wrong.
I went ahead with the final MEU update hoping that it will fix things, but that again only changed one thing:
Navigation: 1170
I did the delete user data thing, but I still don't have carplay. Does anyone have an idea about what might have I done wrong?
Some notes, not sure if they are related:
- Navigation did break for me after the initial MEU upgrade this point (thought I was in Belgium for some reason), but the DCU update fixed it.
- Initially inserting USB 1 didn't do anything for me, but I could still install from USB 2. Still, I inserted USB 1 after that again, just to be safe. When I did the other MEU upgrade, I did get a loading screen with USB 1 though, installed USB 2, and then inserted USB 1 again, which again did not seem to do anything.
Hi, did you still have the files? I have the same navi and I want to update it. Thanks.
Hello,
I'm really curious about this topic and want to give this a try.
But will this work if my player does not have MEU number ?
Only DCU number is found DCU: 17TDT1EU-CA01
thank you.
4 minutes ago, Akie91 said:
Hello,
thank you.
Which country is “other non uk” for you?
I'm from Finland.
Just wondering if this matters ? I thought all Camrys from Europe are basically the same.
My car is missing the navigation option thought.
13 hours ago, Akie91 said:
I'm from Finland.
If you have Panasonic model it's no problem. Normally when the car don't have navigation it's a fujitsu model.
If you have Panasonic model only need the Usb3
I'm quite sure that I have fujitsu model.
Does this mean I cannot get AA on my car ?
Thank you for the reply.
Yes, you can but it's more complex. People install AA/CP flashing the memory but it's not a easy task.
I only test with panasonic model because it's the brand of my car radio
Thanks for the reply.
Flashing the memory meaning I have to solder something on the board? Do you happen to know the source where i can read about it ? I cannot seems to find it.
Do you know if i can just buy a new panasonic multimediaplayer ? Will it be compatible ?
Thanks.
Thanks.
It's not neccessary, only need s programmer but it's dangerous. You can damage your car radio.
I found this information in Russian forum.
You can't change the multimedia player because the pinout in the connectors is different and don't work air conditioner and other thinks 😅
Hello. I read whole this thread and I'm little confused, I have problem in first steps. There is no 86140-06500 folder on this USB. Not matter which folder I choose when i edit this bin file in HEX editor I see different values in first line. Could you give some advice please? I read whole thread but didnt find answer, someone asked with the same problem, but noone answered him.
Here is the screen from hex editor
https://ibb.co/FH93PKg
I have executive version of Camry from 2020. Here i paste the screen https://ibb.co/chYY4x2 where you can see my model of hardware, maybe you have already some ready files for it? If DO i have to go to service menu to find some more informations? Do i have to unplug radio and see the sticker or these data are enough to not unscrew anything in the car?
DCU 17TDT2EU-DA01
MEU 17TMT2EU-FA00
DCU 86140-33D01
MEU 86840-06041
Thank you. Michael from Poland
Hello everyone,
I have a problem with the update.
My model:
DCU: 17DT2EU-DA01 86140-33D00
MEU: 17TMT2EU-FA00 86840-06041
Navbd_version 2021_v1
FROM CV-CS88E0AJ00
FROM2 CV-CS88E0AJ02
I updated to:
DCU: 17DT2EU-DA01 audio: 1020
MEU: 17TMT2EU-FA10 Navigation: 1170
Error 02, I stopped the car and removed USB3, I started the car and got the message  "the update was not done" and now usb 3 doesn't start the installation anymore.
I did USB 3 again, I deleted the files phaseup.dat, 17DT2EU-DA01_7910.kwi, I renamed 17DT2EU-DA31_7910.kwi to 17DT2EU-DA01_7910.kwi and I put the directory 86140-33D00 with the necessary changes.
At this moment usb 3 no longer starts the installation.
86140-33D00.zip
On 18.07.2023 at 11:08, momen1164 said:
Да, я говорю о Denso, я понимаю, что вы имеете в виду, и я знаю, как это сделать.
но меня больше всего беспокоит то, что мой файл 17TD1ME-CA01, так что могу ли я прошить дамп 17TD1EU-CA01?
также любая ссылка на форум, где люди это делают
Hello. I have exactly the same problem with the Denso firmware. Were you able to solve it? If so, how?
Hey guys,
Thanks for the how to and I managed to get Apple Carplay going by means of the description of Alcar.
But now the system is back to audio version 1020...instead of 1023
I thought the parameter error 001 came because that the DCU unit was with errors, so I resetted the errors in the secret screen and decided to do the whole process again after resetting. In my case I have 17TDT1EU-DA02 and renamed the 17TDT1EU-DA30 file. However I inserted the wrong USB3 stick and the original DA02 file started to install on the system. When I saw the process running....It was too late. So now I am trying to use the USB stick with the renamed file but the update process does not start. The system just says checking usb and nothing further happens. If I try to install and updated DA02 file from the Toyota website the car says wrong software version.
Any ideas what to do?
On 4/24/2023 at 11:52 PM, Alcar said:
You can get this data with this option
https://youtu.be/MjvYVUanTa0
Or
https://youtu.be/-YdNyKNZplk
I don't know what I'm doing wrong, but I can't do it. I tried it while the car was running, but it didn't work. I tried again by pressing the start button without pressing the brake, but it still didn't work. I think I'm missing something. Please help me:)
Another EU Camry Touch 2 user here. I am so happy to see there is a solution for this, as the official dealership said, "it's not supported"
DCU: 17TDT2EU-DA01
MEU: 17TMT2EU-FA00
DCU: 86140-33D01
MEU: 86840-06401
I'll try to do the updates in the next days and will report (hopefully happily) 😉
Thanks a lot !!
If you still remember the steps, did you have to rename the files in USB2?
Hello
I have successfully retrofitted last April
To be clear, nothing should be changed in the content of USB1 and USB2
The changes only concern USB3. There are 3 very important modifications
 1 : Delete file phaseup.dat
 2 : Rename the following files
 17TDT2EU-DA00 -> 17TDT2EU-DA30
17TDT2EU-DA31 -> 17TDT2EU-DA01
17TDT2EU-DA32 -> 17TDT2EU-DA02
3 :  Copy the modified folder corresponding to your device into the folder VehicleParameter/DCU
 My device is 86140-33D00
Here the result
Everything works except the toyota oneline connected services. I was able to do the latest map update
 Map Update Spring 2024 Toyota Touch 2 MM17/MM19
I deleted user data after the retrofit, I think it was not necessary to do that
 If you are interested, I will give you the modified file for my device.
86140-33D00.zip
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
