Vin number confirmation (Corona 1974)
Just now, flash22 said:
do you know if it has a square flange (4 bolt) or an ovel flange (2 bolt) that boilts to the booster ?
square mate. I'll try get the guy to send me pics now and add them here
The nearest thing i can find is a Protex JB1225 - 23.8mm INT bore, 2x M10 outlets
Posted (edited)
23.8mm sounds right. Mechanic said it was 23.5mm, but may be listed as 24mm.
I'll have a look at it now and send a link to the garage.
Thanks again for your hard work mate. Really appreciate it
Edited by jackrmee
entered wrong size
I'm starting to think that searching for the RX12 stuff isn't correct, as all the master cylinders for RX12 seem to be 20.6mm diameter
i have been look at RT112 and TT112, 23.8 comes out to old imperial of 15/16 but i cant find a reference for it
just found an oem for the RX12 !! just need to find the size
04313-30051 thats 22mm
Yay found the RX12 15/16 (72-76) - 04493-22060
will keep looking tho
I haven't got a clue how you do it, but I think you could be onto something here.
I'll search for a stockist and check the sizes.
I was looking in a rubber companies pdf found RX, the found RX1#
The RX12 is technically a Cressida !!
Fair play, that's amazing
Here's what I found for part number 04493-22041
This one says it's for 6 cylinder Corona and doesn't fit the 2 litre sedan.
https://www.ebay.co.uk/itm/Brake-Master-Cylinder-Repair-Kit-Fits-Toyota-Corona-MKII-6-Cyl-04493-22041/283677267284?hash=item420c7b9554:g:2eEAAOSwoBFdwvI0
This one says unable to verify correct vehicle
https://www.toyotapartsdeal.com/oem/toyota~piston~04493-22041.html?Make=Toyota&Model=Corona&Year=1974&Submodel=&Filter=()
Sounds like it's not the correct fit?
18R/18RC is the 2.0 engine
04493-22060 is the replacement for both 40 and 41, ergo they must be interchangeable
https://www.ebay.com/itm/Toyota-04493-20040-1973-76-Corona-RT104-RT118-Brake-Master-Cyl-Reb-Kit-W-Pistons-/350880494856
Ok thanks. So you reckon it’s the right part?
Had a reply off the mechanic as well. He sent pics of the markings on the old cylinder. Too difficult to make out any numbers, but the 2nd pic looks to show 15/16 ASCO, so it looks like you’re right about the size mate [emoji4][emoji106]
Sent from my iPhone using Tapatalk
ASCO is the manufacturer, 15/16 is the bore size, it looks like 74 below it
Asco aka Aisin
first pic looks like FR or FB it could even be PR
I haven't yet found the matching master for the piston kit
  • 1 year later...
Hi guys . I have a 1970 corona wagon deluxe. I can’t find any info specific for this year and model.
Hope to hear from someone .
