OBD CODE U2100
UserX86
Recently I had a new alternator and Battery and now the car just doesn't want to start, comes with trouble code U2100.
Any suggestions 🤔.
Thank for your time.
Disconnect the Battery for 15-20 min and let the ecu reset, when a Battery goes flat the ecu has to relearn items like throttle position it also needs to run all of its monitors this can take a good 20-30 min of driving with differing amounts of throttle
A U code is a diagnostic network fault more than likely caused by your scan tool
