Roof Rails
rocket44
Hi folks
Just got myself a  2006 Rav4 but it has come without roof rails.
Does anyone know if you can get replacements (genuine or third party) ?
Also .... are they easy to fit ??
Cheers
Hi. You can get either OEM (quite expensive) or aftermarket (a lot cheaper) ones, plenty of both on eBay. Really easy to fit as well. I would suggest when fitting put some sealant on the bolts as they are prone to leaking.
Hi Kos_ta. Thanks for that. I did have a look on eBay but couldn't se any OEM ones anywhere. The aftermarket ones seem to be limited to just the replacement rail ends (of which there are many).
