Drivetrain
alvorligtalt
I've got a Rav4 2003 model. gasoline 4wd.
Should I be able to rotate the rear drive shaft when in neutral with my hands? If I should, but can't, is it my differential or transmission?  I know I have a bent left rear axle and a worn out u-joint on the rear drive shaft.
Thanks for all answers!
It depends on what the transfer case mode is set to
Not sure what that mean. How do i check the transfer case mode?
