Can't find Crankshaft position sensor, please help
Hi, I have a 1991 Corolla with a 1.6 16 valve engine. I can't get it too start. I am getting spark and fuel, all fuses and relays check out. I am down to the crankshaft position sensor. Can someone please tell me where it is located? Also, I assume there is a camshaft sensor under the distributor cap. Thank you.
If you do find these sensors, what will you do with them?
