2013 6 Speed Toyota Yaris
Ray Bush
Hi ,I want to change the gear stick top the bit that has the 1-6 gears / reverse on it and has a chrome rim .Is there a proper way of removing it ? ,what I don't want to do is to cause any damage other than removing the top bit and fixing a new one.
They're normally screwed on, just grip the gear knob and twist anti clockwise to remove.
Would that be for the very top piece ? ,I don't want to take the whole knob off.
Quote
Its part of the knob tbh, just replace the whole knob
Thanks Bob
The thing is ,you can buy the top part from the main agent without buying the whole knob .I would have thought that if this top piece can be replaced on its own , why buy the whole knob.
They are usually stuck down, a spudger or a teaspoon may do the trick warming it with a hairdrier may help,  tbf there are so many types these days
Edit. found another design the cap is held by a screw from inside the knob
Are they in stock ? Some trim parts show as available but are not
A quick look on eBay
https://www.ebay.co.uk/itm/Brand-New-Toyota-Gear-Knob-6-Speed-For-Yaris-Verso-Auris-Corolla-aygo-Avensis/254620218084?hash=item3b488c32e4:g:-o0AAOSwGn5dk5p0
https://www.ebay.co.uk/itm/Brand-New-Toyota-Gear-Knob-6-Speed-For-Yaris-Verso-Auris-Corolla-aygo-Avensis/254620843823?hash=item3b4895bf2f:g:l3wAAOSwl9BWMmJy
  • 2 months later...
Hey, did you end up buying the replacement gear knob, and was it just a case of unscrewing the existing one from the whole thing?
