hello does anyone know which cruise control i can put on estima aeras 2008?
Moved to the Estima forum
i looked in to fitting cruise control but to have it fitted will be £500 / £700 .
On my 57 reg Hybrid Estima cost me 20£. Only fitted cruise stalk and it started to work straight away.
  • 4 weeks later...
wow thanks. do you mind to tell me where you got it and how you put it in?
I got CC from AliExpress for 20£. To installed it took me 10 minutes. Took of airbag, placed CC in to seating position with 2 or 3 screws ( came with it). Connected harness to the ring( not sure what is a proper name for it). Airbag bag on the steering wheel. Job done. But my Estima is hybrid and I had all wiring from factory, same time guys on petrol Estima had no wiring for CC at all and steering wheel ring was not CC compatible.
