hi guys and ladies, o/s side lights not working !! boath front and rear .. where is the fues located ? Kind Regards
IIRC it will be in the side panel in the passenger footwell...remove the cover and you'll see the fuses but they are a bit fiddly to get to.
I think they are mini fuses IIRC
There's a similar panel with fuses behind in the driver's footwell too but I think (not absolutely 100% sure) in this case it will be the passenger footwell.
2000 is one of those change over years do you know the model code eg, XR10, XR30, etc
if it's the same as the mk1 Previa
Thanks for the help Nieal .... located fuse { passenger well } replaced blown fuse .. jobs a good'n ... also many thanks to those who offered suggestions.
You are welcome, Adrian...glad you got it sorted.!
All my sidelights have gone out after putting an inferior LED bulb in the rear door. I'm suspecting a fuse and i see the panel in the footwell, which is fiddly. Can you tell me which fuse it was, please. Mine is the ACR30 Mk2 2004 Estima.I've checked the 2 small fuses at the back but the square fuses seem to be ok.
Thanks, Phil
All you can do is check all the appropriate fuses and replace as necessary....and yes, it is a bit fiddly.
When you say rear door...would that be a tailgate number plate light.?
Hi. Yes, nice job for the weekend, good job we have light nights. Not the number plate lights, the side lights in the light clusters in the rear door, next to the fixed cluster
It isn't a big job...just fiddly because of the lack of working room..I used long-nose pliers to get the mini fuses out as I couldn't get the standard "puller" to pull them out.
