I was just reading my handbook. It mentions, to check AC filter you have to remove the glovebox. But on checking there is no damper that it mentions. I have a feeling on mine you need not remove the glovebox. The filter housing is atop the glovebox. Is this so ? Is it possible to just slide this out without removing the complete glovebox ??
it's behind the glove box, the glove box unclips and swings down or lifts out its at most a 5 min job
Hi thanks flash.
Yes I think you just press the sides of the glovebox for it to come out. Will have a go in the morning.
it's the same procedure on most Toyota's. Unclip/unscrew the damper on the side - push the glove box to one side to unhook the clips
heres a vid on an auris (same principle)
Thanks. I looked at mine this morning. Glad I did, it was black and full of rubbish.
I have ordered a new one.
