help with prius zvw30 radio loom aux
F139
hi Guys
good afternoon
my t4 prius have a aux connection but doesnt have a audio usb connection and I would like to buy a audio usb a loom to connect in my factory radio.
does anyone know if the prius radio have entry to connect a usb loom
What radio do you have ? uk car or a jdm import ?
is it the 6" touch screen B9016 ?
sorry I am noob on Toyota.
how do I know that?
That's for the later units you have a 86120-47301 radio
so do you think there is no chance to add a usb aux to my OEM radio?
Im just looking to see if it has cd changer control
THANK YOU VERY MUCH
I think I will have to try
I really appreciate all your help.
Kind regards
F139
It doesn't look like its compatible - Fujitsu Ten model is 13847 it may be worth a try tho
When i had a 2010 gen3 prius T3 i was able to buy a third party touchscreen head unit that was a straight swap for the Toyota CD radio that came as standard. Not sute if they are still around. You can also fit a standard double din unit and buy some plastic fills to plug the gaps.  There is a handy thread or 2 on prius chat.  Be aware that the gen3 head units and fill pieces come in left and right hand drive variants. The hole is not symetrical. 😞
Have a rummage here
https://priuschat.com/forum/gen-3-prius-audio-and-electronics.98/
Hi johalareewi and flash
thank you both for help.
I just lost my mind today and took my radio apart
I bought as well a 6-6 pin (https://electropapa.com/en/aux-line-in-adapter-cable-car-radio-for-toyota-prius-2004-2010-car-vehicle-usb?currency=GBP&utm_source=google_shopping&gclid=Cj0KCQjwuJz3BRDTARIsAMg-HxUT2sIux0T0MawQ78v0i2PSzSUILaAdQ6KQD_l9xyrcLztJUhpxE4YaAiPqEALw_wcB) and I will try my luck.
I saw on youtube someone doing this. (https://www.youtube.com/watch?v=8UXbe5rLaHI&t=209s) and i hope that I can do the same but my adaptor doesnt have bluetooth once my car has.
hopefully tomorrow once the adaptor arrive I will update you
HI Guys
I am happy to tell you that the radio work with https://www.amazon.co.uk/Digital-Interface-Adapter-TOYOTA-Corolla/dp/B0711J4FFF this adaptor for 32£
its easy to install once is only connect the 12 pin connector and send the cables (usb female and 3.5mm audio cable) to the lower vacant slot under the dash.
thank you all for your help and hope this can help someone
ps. my 12 pin slot was unused but if your is used you can buy a 12 pin y connection https://www.ebay.co.uk/i/402019571644?chn=ps&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=402019571644&targetid=908661474856&device=c&mktype=pla&googleloc=9044970&poi=&campaignid=10204071591&mkgroupid=104953044434&rlsatarget=aud-629407026465:pla-908661474856&abcId=1145987&merchantid=137623825&gclid=CjwKCAjw26H3BRB2EiwAy32zhSBYtwuDIsued7KGy4TVA4nIDMMRl-DvBY5Efsh1yGEHtMxYU0TClxoCdUAQAvD_BwE
