Hi I have a corolla 2006 1.6 hatchback and my rear washer is not spraying any screen wash. My windscreen washer works fine you can hear the pump and the screen wash is spraying all over the windshield. When I am trying to use the rear one there is no sound at all and of course no screen wash spraying in the back. I had this issue intermittently before but now it just doesn't work at all. When I twist the rear washer knob the rev in the car go down slightly so the car is trying to use the pump if you know what I mean but it is not cooperating. Question is in this model of the car do I have separate washer pumps or is it one pump for both front and back? I know it might be obvious because front seems to be operating just fine but I want to double check.
They have 2 washer pumps, had to replace the rear one for mine last year
  • 3 years later...
Hi thanks for the reply. I replaced the rear washer pump and it worked again. After couple of months it stopped working again. But the pump is working its just the nozzle at the ack that broken or blocked. When i remove the hose near the hinge the water is flowing out of it. I managed to unclog it once and it sprayed again but it got blocked again and im unable to unclog it.
I cant replace it because of the spoiler blocking access and it cant be removed without potentially damaging it. So I am stuck with a broken rear washer hahahaha
