Prius ZVW30 battery log
F139
HI
Good evening
Can I ask if anyone have knowledge about Prius Battery and can tell me if the batteries on my Prius are in good condition or in bad condition please.
I did a log with DR. Prius app and I don't understand nothing of this numbers so if someone can help me I will appreciate.
the colours I have added them to make easy see the different values once was all only white.
thank you
You should run the Battery life expectancy test in Dr. Prius, looking at the voltages and resistance only when the car is idle won't tell you much.
hi Quantum
Good evening
thank you very much.
will not the test damage my batteries? its Safe?
Kind Regards
