Reverse cam for TAS500 in Hybrid from 2014
Ocap112
Hello  Carlos
Selling the TAS 500 ?
May I asking why ?
Is it so difficult to install the radio ?
Thanks in advance .
Hi Fred,
Not at all, I have exchanged the yaris for a 2021 corolla at the toyota dealer and I decided to deliver it with the original radio.
The radio works perfect and the camera is just as the good friend flash said.
the new car has already integrated android auto and Apple carplay as standard.
best regards,
Carlos
if you know someone who is interested let me know and we can negotiate. my email is carloseduarneta@gmail.com
regards
hi all, I have recently installed a tas500 but I can't get the rear camera to work.  what can I do?  thank you
Hello.
Maybe Carlos can give you some tips !
Send him a private message .
Regards .
Its all on page 3 of this thread
iirc carlos never got around to fitting the tas500 fully
TL:DR
you need a reverse signal from the reverse light to pin 2 on the 28 pin, the camera input is 2-3 wires
If you solve the camera problem. I will buy TAS500 too. For the 2013 Yaris. There is a Touch & Go version and it will be incredible if I can update it.
Do you have any updates?
It works but I would suggest that before buying it, you should get in contact with a workshop and explain them the modifications needed (which are explained on this forum).
  • 4 months later...
I ve installed successfully the TAS 500 in my Yaris.
Reverse camera signal was found close to OBD port.
i am not sure what the adapter harness is for, but it doesnt seem very usefull
I don't have much info on these tas-500, there is 1 update for these units, i will have a look to see what the update pdf says
On 9/10/2021 at 4:55 PM, durix said:
Well done! I think that is the easiest way to connect the reverse signal to the tas500.
I have one "issue" during phone calls people complains that sound is not very good, i hope to find some info on the mic in this menu.
@flash22do you know how the update is done also?
thanks!
I think the latest service bulletin is still referring to the update from april 2020, also discussed here:
But maybe @flash22 knows more.
4 hours ago, durix said:
my version is 19.6.0
That is up-to-date then check the microphone its is clean and plug/unplug the connector from it
I don't know of any hidden menus of the TAS500 as it's based on a different system to the touch2
i received an accessory for TAS500, the applepie mini
It is and android box connected through the carplay interface of TAS500
It has built in 4G Sim, dual bluetooth and GPS and gives full android functions on TAS500.
So you can run any android apps on it without carplay or Android Auto restrictions and connect to your personnal phone to receive phone calls.
It also enables wireless carplay and android Auto.
i really love it.
Heres a review on it:
If you have any question don't hesistate
By the way, regarding the topic of this forum: "Reverse Camera". I think we could close this topic as solved. I have followed the instructions from @durix and it was pretty easy to connect the rear camera to the TAS500 even for a non-expert like me. Maybe you can share some more pictures here too.
The thread is still useful to other members - click on the follow button at the top of the thread, either set your notification settings or click unfollow, so you don't receive any more notifications
