:crybaby::crybaby: I have just found out that my water pump has developed a very serious leek.
i need to get another one quick. is the pump on the ae92 gti the same as the one on my levin, they have similar 4age engines.
Jae only 10 days away and i dont want to miss it :help:
yes just get a 4age water pump from anywhere....
So a pump from a 4age 16 valve will defo fit then?
yup a 4ag engine block is just that no matter how many valves or what induction system you fit to it.
:D thanks alot mate, you have just saved me some cash and alot of worry,
I can get a pump for a 4age 16 valve for £25 today, instead of £100 for the imported one for a 20 valve which might have not made it in time for JAE. :thumbsup:
I have just seen an article on another web site, where a bloke said he had tried to fit a pump for a 4afe Ae101, onto his ae92 20 valve and it did not fit, he had to grind down part of it to clear the timing belt, and that the pulley seat was not the same.
I'm having doubts about other pumps fitting the 20 valve block, any thoughts..
