Auris hybrid
Josey
Hi my car has done 40000 miles. I change oil and filter at a interval of 10000miles. I haven’t changed any other things. Do i need to change gear oil, plugs and some other things. Thank you
auris hybrid estate 2014
Hi, best to check the manual but at this mileage you don’t need to worry about plugs and gear oil, these are to be changed at 60k miles. You need to change brake fluid, pollen(Cabin) filter, air filter and Wiper Blades if necessary. I think that’s pretty much what you need to do.You can also  Install a cat lock too if you haven’t done so and debadge, remove all hybrid emblems from the car to make it look like non hybrid Toyota as precautionary measure against thefts.
Regards
Have a look on your manual for the service schedule but I would have thought at the very least change the air filter, pollen filter, brake fluid, top up coolant.
If you have the service and warranty book, that outlines the service requirements.
