I bought a  as-pl rectifier compatible with my denso alternator.
It's just like the old one, but the old one has 6 diodes and the one I bought has 8.
Is there any problem in applying it?
Thanks.
The plates are just like in the pictures.
Looks like the diodes are wired in parallel, so probably the 8 one will handle a higher current from a more powerful model.
Worth asking your supplier or Denso uk if they are compatible.
Get it wrong and you could  blow your alternator, Battery and more, even start a fire !
In the specifications it is compatible.
From what I was researching and realized, all these replacement rectifiers from Denso, went from 6 to 8 diodes and have their own measures for that.
