T-sport 2002 Ph1Oil feed location
pio14343
After some advice on oil feed for forced induction..
Seen people write about feeding (from front of engine bay, under intake manifold with T-mounts to turbo and top part of oil pan)
Unsure as to what are the exact fittings... BPT, NPT 1/8 or Bpt to Npt adaptors?
Which should fit perfectly for the oil pressure sensor hole?
Advice would be much appreciated 🙂
Feed - using a T off the oil pressure switch (under the intake) a quick google for the sensor shows it's an 1/8 "gas" thread
Edit. Many manufactures show it a BSPT (BSP Taper)
Drain into the sump -10 AN at the rear
unless you want to go with -6, -8 or -10 lines stick with BSP
Found this site years ago and have used them over the years for fittings, decent quality at a good price http://www.speedograph-richfield.com/html/instrument_accessories.html
lines and race type stuff https://www.merlinmotorsport.co.uk/
There are a lot of pics over on the yarisworld forum tbh its very quiet over on there
