weird misfiring
Gc01
Hi, I've been having some car troubles today so I turned on my car and it was fine then I drove it forward and it started misfiring and it was idling badly and I had to keep reving it to stop it from cutting out. It was running fine last week I havent done any changes. Also the power steering light comes on. Now the car has electric power steering so there is no pump to replace so I don't know what to do.
Check the Battery voltage across the terminals (with ignition off)
Anything less than 12.4V suggests Battery is dead or alternator faulty.
If the Battery is  more than 5-6 years old, odds are it's the battery - especially if car has not been used much. Try putting the battery on a charger. (borrow if possible)
Garages selling batteries will usually do a check.
But  as above , it could be the alternator
