Has anyone replaced the original interior halogen bulbs with LEDs and can specify which type of bulbs are used for the front, back, glove-box, sun-visor lights?
Interested in this too, was thinking of also chaning the halogen bulbs of the number plate.
Can you show us a picture of how it looks?
Here You go.
There's actually a tutorial on how do change these in Toyota's own user manual as well. I think it was under maintenance. Just be careful with prying these bulb covers (lenses) out. Use some plastic tool.
  • Like 3
Visors are also W5W
Boot depending on trim is either already LED strips or a W5W
Centre roof lamp: with pano roof 10x30 feston, without pano roof W5W
Front roof lamp has holder mounted bulb and is not listed by bulb type, part # 81936-12160
If they're the same as the Prius they are the 194 wedge type bulbs (aka 501,W5W), accessed from the top of the unit
Just looked it up Prius and PHV 2015 onwards, Auris 2009 onwards use the same holder(s)
  • 1 year later...
Can someone explain on how to change license plate bulb on corolla touring 2019 please
  • 2 months later...
The vanity light units fall apart when being removed if you aren't very careful indeed...
