2009 rav 4 front tyre wear uneven
Mattch5150
hi all, I have a 2009 2.2 d4d 140. Ive noticed the outer edge of the passenger side front tyre has worn anout 2-3mm lower than the other tyres. Pressures checked 2 weekly, and wheel alignment has been done. Car has done 102000 miles. Front springs are ok. Is it likely that worn shocks could cause this or is there anything else to try?
Cheers
My 2007 shows the same wear. Never figured it out. Had it 10 years now. Alignment fine too.
